Below are some recommendations for using Altair Driver:
            - Symptom
            - The driver simulation fails immediately.
            - Remedy
            - Verify that the vehicle position is consistent with the specified path. The path
              points need to be close to the vehicle at design position.
            - Symptom
            - The driver seems to turn the steering wheel angle counter-intuitively and it does
              not follow the prescribed path. The simulation fails.
            - Remedy
            - This is probably caused by positive feedback. This can be fixed by reversing the
              sign of the steering wheel angle signal or the steering rack ratio.
            - Symptom
            - The driver follows the path, but it is too sluggish. The simulation fails.
            - Remedy
            - This could be caused by a preview time that is too long for the maneuver and the
              vehicle speed, especially if the steering signal seems to start responding too soon.
            - Symptom
            - The driver follows the path, but its actions are too sudden and the steering wheel
              angle signal is too jumpy.
            - Remedy
            - This could be caused by a preview time too short for the maneuver and the vehicle
              speed, especially if the steering signal seems to start responding too late.
