Frequency Response Assurance Criterion (FRAC)
Frequency Response Assurance Criterion (FRAC) is a measure of the correlation between two frequency response functions (FRFs) representing the same input-output relationship.
Supported vibration shapes include:
![](../../images/post_processing/nvh_frac_equation_hv.png)
- H3D – binary result file typically generated using OptiStruct.
- OP2 – binary result file typically generated using OptiStruct or Nastran.
- PCH - ASCII result file typically generated using OptiStruct or Nastran.
- UNV – ASCII result file typically exported from testing software.
