bolt (general)
LS-DYNA
Nastran and OptiStruct
Creates RBE2 elements for the head and the body. The head elements project and connect to the nodes of the adjoining shell elements which form the hole. The connector location can either be on the edge of the hole, center of the hole, midpoint in between the two holes or on the second row of nodes which form the washer layer.
Radioss
Creates RBODY elements for the head and SPRING2N body. The head elements project and connect to the nodes of the adjoining shell elements which form the hole. The connector location can either be on the edge of the hole, center of the hole, midpoint in between the two holes or on the second row of nodes which form the washer layer.
This realization also the prop_radioss_rigidupdate.tcl property script.
![](../../../../images/cfg_nastran_52_bolt.png)
