HC cylinder spring bolt
LS-DYNA
![](../../../../images/cfg_dyna_121_adhesive.png)
Radioss
This realization creates a SPRING element for the body, and projects and connects the element to nodes of the adjoining shell/solid elements with RBE2 elements within the prescribed cylinder diameter, L1 (cylinder height along the vector from the connector location) and L2 (cylinder height in the opposite direction of the vector from the connector location).
![](../../../../images/cfg_radioss_65_hc_cylinder_spring_bolt.png)
