Use the Refine: Auto Quads tool to
refine elements as quads based on a given refinement size. Transition elements may be
automatically defined or manually selected.
From the Elements ribbon, click the tool.
- Optional:
On the guide bar, click
to define refinement
options.
Choose Elements or Nodes using
the Refine selector on the guide bar.
Select entities.
If Type is set to Use adjacent layers, the
transition elements are previewed on each side of the selected entities.
If Type is set to Select transition elements, click
Transition on the guide bar
then manually select transition elements.
Input a refinement value in the microdialog then click
Refine.
