Create Thin Solid Mesh
Use the Thin Solids tool to create 3D mesh on thin solids. The mesh is created by first generating a 2D mesh on a selected set of source faces, and then extruding this mesh to generate solid hexa or wedge elements.
In order to create a thin solid mesh, the solid geometry must meet a certain criteria.
- The solid entity should be a sheet metal solid. The thickness should be less than other the two dimensions (length and width).
- You should be able to identify both the Source (start) faces and the Target faces.
- Source and destination faces must be connected by side (along) faces which are almost 90 degrees to them.
