Add Representations from the Part Library
- In the Part Browser, right-click on a part/part assembly and select Representations > Add > from Library from the context menu.
- In the Add Representations from Library dialog, select representations to add.
- Optional: To simultaneously add and load representations, select representations to load from the Load Added Representations list.
Click OK.
