The beam cross section is always defined in a y,z plane.
            The x-axis is defined along the beam axis. The coordinate system you define is called
                the local coordinate system; the system parallel to the local coordinate system with
                the origin in the centroid is called the centroidal coordinate system; the system
                referring to the principal bending axes is called the principal coordinate
                system.
            For shell sections, only the theory of thin walled bars is used. This means that for
                the calculation of the moments and product of inertia, terms of higher order of the
                shell thickness t are neglected. Thickness warping is also neglected.
                        - Area
                        - Area Moments of Inertia
                        - Area Products of Inertia
                        - Radius of Gyration
                        - Elastic Section Modulus
                        - Max Coordinate Extension
                        - Plastic Section Modulus
                        - Torsional Constant
                                    - Solid
                                    - ω - Warping function
                                    - (see below for warping function)
                                    - Shell open
                                    - t - Shell thickness
                                    - Shell closed
                                         - Area enclosed by cell
                                         - Shear flow in cell
                        - Elastic Torsion Modulus
                                    - Solid
                                    - Shell open
                                    - Shell closed
                        - Shear Center
                        - Warping Constant (normalized to the shear center)
                        - Shear deformation coefficients
                        - Shear stiffness factors
                        - Shear stiffness
                        - Warping Function
                        - For solid sections, the warping function is computed using a finite
                            element formulation. This may lead to un-physically high stresses in
                            geometric singularities (sharp corners) that get worse with mesh
                            refinement. This may cause problems computing the elastic torsion
                            modulus.
        Nastran Type Notation
