Create and Edit a Semi Infinite Fluid (SIF)
An acoustic element represents the infinite propagation medium for an exterior radiation scenario/problem. It can be attached to multiple acoustic subsystems to transfer the energy. The acoustic connections automatically consider the propagating surface area for connections. This element automatically creates semi-infinite acoustic space and connects the exterior-most acoustic space that you select.
