Force: Bushing
Command ElementModifies a BUSHING force element.
<Force_Bushing
id = "integer"
i_marker_id = "integer"
j_marker_id = "integer"
kx = "real"
ky = "real"
kz = "real"
ktx = "real"
kty = "real"
ktz = "real"
cx = "real"
cy = "real"
cz = "real"
ctx = "real"
cty = "real"
ctz = "real"
preload_x = "real"
preload_y = "real"
preload_z = "real"
preload_tx = "real"
preload_ty = "real"
preload_tz = "real"
Attributes
- id
- Element identification number (integer>0). This number is unique among all Force_Bushing elements and uniquely identifies the element.
- i_marker_id
- Specifies the Reference_Marker at which the force is applied. This is designated as the point of application of the force.
- j_marker_id
- Specifies the Reference_Marker at which the reaction force and moment are applied. This is designated as the point of reaction of the force.
- kx, ky, kz, ktx, kty, ktz
- These define the diagonal entries for a 6x6 stiffness matrix that is used to calculate the spring force for Force_Bushing. All stiffness values must be non-negative, in other words, Kij ≥ 0.
- cx, cy, cz, ctx, cty, ctz
- These define the diagonal entries for a 6x6 damping matrix that is used to calculate the damping force for Force_Bushing. All damping values must be non-negative, in other words, Cij ≥ 0.
- preload_x, preload_y, preload_z, preload_tx, preload_ty, preload_tz
- These define the pre-loads in the Force_Bushing element. In other words, the forces at I when there is deformation. The force and torque components are measured in the J coordinate system. The first three components define the pre-load force while the last three are pre-load torques. The data is optional. Their default values are 0.
<Force_Bushing
id = "207006"
kx = "6000."
cx = "6."
preload_x = "0."
ky = "6000."
cy = "6."
preload_y = "0."
kz = "1000."
cz = "1."
preload_z = "0."
ktx = "500000."
ctx = "500."
preload_tx = "0."
kty = "500000."
cty = "500."
preload_ty = "0."
ktz = "100000."
ctz = "100."
preload_tz = "0."
