/EOS/PUFF
Block Format Keyword Describes the linear polynomial equation of state P ( ρ , E ) .
/EOS/PUFF/mat_ID/unit_ID
eos_title
C1 C2 C3 γ 0
T1 T2 Es
H E0 ρ 0
Definition
mat_ID Material identifier.
(Integer, maximum 10 digits)
unit_ID Unit Identifier.
eos_title EOS title.
C1 C1 coefficient. 1
(Real)
[ Pa ]
C2 C2 coefficient.
(Real)
[ Pa ]
C3 C3 coefficient.
(Real)
[ Pa ]
γ 0 Gruneisen gamma.
(Real)
T1 T1 coefficient. 1
Default = C1 (Real)
[ Pa ]
T2 T2 coefficient.
(Real)
[ Pa ]
Es Sublimation energy per unit initial volume.
(Real)
[ J m 3 ]
H H coefficient. 1
(Real)
E0 Initial energy per unit initial volume.
(Real)
[ J m 3 ]
ρ 0 Reference density.
Default = material density (Real)
[ kg m 3 ]
Example (Copper)
#RADIOSS STARTER
/UNIT/1
unit for mat
                   g                  cm                 mus
#-  2. MATERIALS:
/MAT/HYD_JCOOK/1/1
Copper
#              RHO_I               RHO_0
                 8.9                   0
#                  E                  nu
                 1.3                 .34
#                  A                   B                   n              epsmax              sigmax
                9E-4              .00292                 .31                   0                   0
#               Pmin
                   0
#                  C           EPS_DOT_0                   M               Tmelt                Tmax
                .025                1E-6                1.09                1356                1E30
#              RHOCP                                                         T_r
            3.432E-5                                                           0
/EOS/PUFF/1/1
Copper
#                 C1                  C2                  C3                  G0
              1.3597              2.7466              2.4479                1.97
#                 T1                  T2                  ES
                   0                   0             0.12282
#                  H                  E0               RHO_0
                   1             1.25675                   0
#ENDDATA
  1. Let μ = ρ ρ 0 1 , η = 1 + μ , x = 1 ρ 0 ρ and E, the internal energy per unit initial volume, the pressure is defined by:
    Region 1: μ 0 (1)
    P = ( C 1 μ + C 2 μ 2 + C 3 μ 3 ) ( 1 γ μ 2 ) + γ ( 1 + μ ) E
    with γ ρ = γ 0 ρ 0
    Region 2: μ < 0 and E E s (2)
    P = ( T 1 μ + T 2 μ 2 ) ( 1 γ μ 2 ) + γ ( 1 + μ ) E
    Region 3: μ < 0 and E E s (3)
    P = η [ H + ( γ 0 H ) η ] [ E E s ( 1 exp ( N ( η 1 ) η 2 ) ) ]
    with N = C 1 η γ 0 E s
  2. Equations of state are used by Radioss to compute the hydrodynamic pressure and are compatible with the material laws:
    • /MAT/LAW3 (HYDPLA)
    • /MAT/LAW4 (HYD_JCOOK)
    • /MAT/LAW6 (HYDRO or HYD_VISC)
    • /MAT/LAW10 (DPRAG1)
    • /MAT/LAW12 (3D_COMP)
    • /MAT/LAW49 (STEINB)
    • /MAT/LAW102 (DPRAG2)
    • /MAT/LAW103 (HENSEL-SPITTEL)
1 "The PUFF 66 Computer Programs" Brodie, Hormuth, Air Force Weapon Laboratory, May 1966.
