/EOS/SESAME
Block Format Keyword Describes the SESAME table equation of state.
/EOS/SESAME/mat_ID/unit_ID | |||||||||
eos_title | |||||||||
E0 | |||||||||
SESAME301 | |||||||||
Definition
mat_ID | Material
identifier. (Integer, maximum 10 digits) |
unit_ID | Unit Identifier. (Integer, maximum 10 digits) |
eos_title | EOS title. (Character, maximum 100 characters) |
E0 | Initial energy per unit
reference volume. (Real) |
Reference
density. Default = material density (Real) |
SESAME301 | File name for SESAME table
#301. (Character) |
- unit_ID does not apply to the table which should be given in its native units: 1
Density:
Pressure:
Energy:
- The table is automatically converted in the Work Unit System, defined in the /BEGIN keyword.
- Equations of state are used by
Radioss to compute the hydrodynamic pressure and are
compatible with the material laws:
- /MAT/LAW3 (HYDPLA)
- /MAT/LAW4 (HYD_JCOOK)
- /MAT/LAW6 (HYDRO or HYD_VISC)
- /MAT/LAW10 (DPRAG1)
- /MAT/LAW12 (3D_COMP)
- /MAT/LAW49 (STEINB)
- /MAT/LAW102 (DPRAG2)
- /MAT/LAW103 (HENSEL-SPITTEL)
