/FRAME/FIX
Block Format Keyword Describes the frames.
/FRAME/FIX/frame_ID/unit_ID | |||||||||
frame_title | |||||||||
Ox | Oy | Oz | |||||||
X1 | Y1 | Z1 | |||||||
X2 | Y2 | Z2 |
Definition
frame_ID | Reference frame
identifier. (Integer, maximum 10 digits) |
unit_ID | Unit Identifier (Integer, maximum 10 digits) |
frame_title | Reference frame
Ox | X coordinate of frame
origin O' (Real) |
Oy | Y coordinate of frame
origin O' (Real) |
Oz | Z coordinate of frame
origin O' (Real) |
X1 | X component of frame axis
(Real) |
Y1 | Y component of frame axis
(Real) |
Z1 | Z component of frame axis
(Real) |
X2 | X component of axis
' (Real) |
Y2 | Y component of axis
(Real) |
Z2 | Z component of axis
(Real) |
- The reference frame identifier must be different from all skew identifiers.
- The reference frame is fixed and its directions are defined by and . Vectors of arbitrary length may be given.
- Input is
axis and
axis, but X' axis is computed
as:
(1) is recomputed as:(2) Therefore, the new reference frame is defined by , ', and .
