/H3D/SPRING
Engine Keyword Generate H3D contour output results for /SPRING spring elements.
/H3D/SPRING/Keyword3
#optional next line(s) that lists the parts to save results for
part_ID1... part_IDN
/H3D/SPRING/DT/H3D/SPRING/FORC
356 293Definition
| Keyword3 | Output types. 3 | |
| part_IDN | Optional list of part IDs for which results will be output. |
- The syntax /H3D/ELEM/Keyword3 is also valid.
- When PART IDs are listed after the /H3D/SPRING line the specified results will only be output for those parts.
- The scalar output is defined in the
following tables.
Table 1. Scalar Output Keyword3 Description AMS Elements using AMS timestep due to /DT/CST_AMS. DAM1, DAM2, DAM3 Damage in direction 1, 2 or 3. 4 DT Element timestep. ENER Specific energy density (internal energy divided by the element mass). EPSP Plastic strain. F1, F2, F3 Force in local coordinate system. - F1
- Force in X direction
- F2
- Force in Y direction
- F3
- Force in Z direction
FORC All forces and moments in local coordinate system. F1, F2, F3, M11, M21, M31, M12, M22, M32.
GROUP Internal group identifier M11, M21, M31, M12, M22, M32 Moment in local coordinate system. - M11
- Moment in X at node 1
- M21
- Moment in Y at node 1
- M31
- Moment in Z at node 1
- M12
- Moment in X at node 2
- M22
- Moment in Y at node 2
- M32
- Moment in Z at node 2
MASS Element mass OFF Element status. Where the result output is:- = -1
- Element is not active (it is defined in an activated rigid body).
- = 0
- Deleted element.
- Between 0 and 1
- Under failure process.
- = 1
- Active element.
- Damage in springs is
defined as the maximum value between time 0 and the current time of the displacement
versus failure displacement ratio:
(1) For TYPE13 (/PROP/SPR_BEAM) springs, damage direction 1 is traction/compression, 2 and 3 are shear y and z.
For TYPE8 (/PROP/SPR_GENE) springs, damage directions 1, 2 and 3 are, respectively x, y and z.
