/SURF/SUBSET/ALL
Block Format Keyword Describes the subset surfaces which belong to given subsets.
| /SURF/SUBSET/ALL/surf_ID/unit_ID | |||||||||
| surf_title | |||||||||
| item_ID1 | item_ID2 | item_ID3 | item_ID4 | item_ID5 | item_ID6 | item_ID7 | item_ID8 | item_ID9 | item_ID10 |
Definition
| surf_ID | Surface
| unit_ID | Unit Identifier (Integer, maximum 10 digits) |
| surf_title | Surface
| item_ID1, item_ID2,... item_IDn | List of subset
identifiers (Integer) |
- The format is the same as the corresponding options /SURF/type/surf_ID.
- For solid elements, a surface segment is created for
every face of a solid element that belongs to the item_ID
listed.
The segments built from 3-node and 4-node shells are still selected the same way as with /SURF/type/surf_ID.
