/TH/BEAM
Block Format Keyword Describes the time history for beams.
/TH/BEAM/thgroup_ID | |||||||||
thgroup_name | |||||||||
var_ID1 | var_ID2 | var_ID3 | var_ID4 | var_ID5 | var_ID6 | var_ID7 | var_ID8 | var_ID9 | var_ID10 |
elem_ID | elem_name |
Definition
thgroup_ID | TH
group identifier (Integer, maximum 10 digits) |
thgroup_name | TH
group name (Character, maximum 100 characters) |
var_ID1, ...n | Variables saved for
TH (see table below) (Character, maximum 8 characters) |
elem_ID | Element
identifier (Integer) |
elem_name | Name of the element to
appear in the time history (Integer, maximum 80 characters) |
TH Output Keyword & Variables
Keyword | Object Saved | Variables |
BEAM | Beams | OFF, F1, F2, F3, M1, M2, M3,
IE SX, SXY, SZX, SX_i, SXY_i, SZX_i (with i from 1 to 81) EPSP, EPSP_i (with i from 1 to 81) |
Table of Available Variables - Part 2
Keyword | Variable Group | Saved TH Variables |
BEAM | DEF | OFF, F1, F2, F3, M1, M2, M3, IE |
Output for Available Material Law
Output | Material Law |
OFF: element flag for deactivation 2 | All material compatible with beam element |
F1: normal force in direction 1 | All material compatible with beam element |
F2: shear force in direction 2 | All material compatible with beam element |
F3: shear force in direction 3 | All material compatible with beam element |
M1: torsional moment | All material compatible with beam element |
M2: bending moment in direction 2 | All material compatible with beam element |
M3: bending moment in direction 3 | All material compatible with beam element |
IE: internal energy | All material compatible with beam element |
SX: tensile stress direction 1 | All material compatible with beam element |
SXY: tensile stress direction 2 | All material compatible with beam element |
SZX: tensile stress direction 3 | All material compatible with beam element |
SX_i: tensile stress direction for the integration point i (from 1 to 81) | All material compatible with integrated beam |
SXY_i: shear stress direction 2 for the integration point i (from 1 to 81) | All material compatible with integrated beam |
SZX_i: shear stress direction 3 for the integration point i (from 1 to 81) | All material compatible with integrated beam |
EPSP: plastic strain | PLAS_PREDEF, 2, 36 and 44 |
EPSP_i: plastic strain for the integration point i (from 1 to 81) | PLAS_PREDEF, 2, 36 and 44 |
- Available names are listed in the two
tables above.
In the first table, TH-variables are listed. If a TH-variable is requested, this variable is written.
In the second table, other variable groups are listed. If a variable group is requested, all the associated TH-variables are written at once.
- OFF:
- 0.0 deleted element
- 1.0 active element
- 2.0 (shells / solids): active element using small strain
- Negative value -1/-2 when the element is on stand-by due to rigid body
- Some intermediate values can be found during few cycles before element deletion (progressive reduction of off during a few cycles applies as a multiplicative factor to the stress, so that the stress is progressively vanished, and element is deleted after ~ 10 cycles). This process applies to some element types, not all.
