/TH/SLIPRING
Block Format Keyword Describes the time history for sliprings.
| /TH/SLIPRING/thgroup_ID | |||||||||
| thgroup_name | |||||||||
| var_ID1 | var_ID2 | var_ID3 | var_ID4 | var_ID5 | var_ID6 | var_ID7 | var_ID8 | var_ID9 | var_ID10 |
| Obj_ID1 | Obj_ID2 | Obj_ID3 | Obj_ID4 | Obj_ID5 | Obj_ID6 | Obj_ID7 | Obj_ID8 | Obj_ID9 | Obj_ID10 |
Definition
| thgroup_ID | TH
group identifier (Integer, maximum 10 digits) |
| thgroup_name | TH
group name (Character, maximum 100 characters) |
| var_ID1, ...n | Variables saved for
TH. See TH Output Keywords &
Variables. (Character, maximum 8 characters) |
| Obj_ID1, ...n | Identifiers of the objects
to be saved (Integer) |
TH Output Keyword & Variables
| Keyword | Object Saved | Variables |
| SLIPRING | Sliprings | RINGSLIP, FN, F1, F2, THETA, GAMMA |
Table of Available Variables - Part 2
| Keyword | Variable Group | Saved TH Variables |
| SLIPRING | DEF | RINGSLIP, FN, F1, F2, THETA, GAMMA |
Output for Sliprings
- RINGSLIP: total amount of material crossing the slipring
- FN: normal force on slipring
- F1: axial tension in strand 1 of the slipring
- F2: axial tension in strand 2 of the slipring
- THETA: angle between slipring strands
- GAMMA: orientation angle of the seatbelt
- The ringslip is positive when the material moves from elem1 to elem2 and is negative if the flow of material is in the opposite direction.
