Command Line Execution
You can install and invoke SimSolid from the operating system command line.
Installation
SimSolid supports installation from the command line. This is intended to centralize remote management and better support large installations.
Start /wait Simsolid-setup.exe /S /D=<installationfolder>Where:
/Sindicates silent install/Ddefines the installation folder
/D must be the last parameter on the command line and
the string must not contain quotes even if the part contains blank spaces.
The above options are case-sensitive, so /S will work,
but /s will not.
start /wait /D"C:\Program Files\SimSolid\SimSolid" uninstall.exe "/S _?=C:\Program Files\SimSolid"
Invocation
You can invoke SimSolid and import geometry from the operating system command line. Optional parameters are provided to specify CAD input file(s) and geometry import settings. You do not need to specify the CAD file format; it will be auto-detected.
Optional Parameters
-for--file <file_path>Note: You can use this option multiple times to import multiple files.-ror--resolution <standard | enhanced | fine | custom>(Optional. Default is standard.)-aor--angle <angular_deviation_in_degrees>(Optional. Default is 15.0.)-cor--chord <chordal_deviation_in_mm>(Optional. Default is 0.635)-
-mor--method <ct | parasolid>(Optional. Default is parasolid.)
Invocation Examples
simsolid.exe -f C:\Models\example1.x_t
simsolid.exe --file C:\Models\example1.x_t
simsolid.exe -f C:\Models\example2.prt -r enhanced
simsolid.exe --file C:\Models\example2.prt --resolution enhanced
simsolid.exe -f C:\Models\example3.asm.1 -r -a 5 -c 0.1 -m ct
simsolid.exe --file C:\Models\example.asm.1 --resolution custom --angle 5 --chord 0.1 --method ct
Batch Mode
This mode enables you to run various operations by executing a JavaScript file through command line arguments. Modal analysis with regular connections is currently supported. You cannot apply boundary conditions with batch mode.
This capability is only available for the full version of SimSolid.
- Syntax
- The command line syntax for running operations in batch mode is as
follows:
Start /wait <Path to SimSolid installation folder>\simsolid.exe -s <JavaScript file path> -l <log file>Where:
-sindicates the JavaScript file to be executed-ldefines the log file
Example:start /wait C:\Program Files\Altair\SimSolid\2020.2\simsolid.exe -s C:\Models\Batch\modal.js -l C:\Models\Batch\log.txt - Parametrization
The JavaScript file can be parametrized and executed via command line arguments. You can parametrize any value using %#% , meaning %1% indicates parameter #1, %2% indicates parameter #2 and so on.
The command line syntax for running with parameters is as follows:
Start /wait <Path to SimSolid installation folder>\simsolid.exe -s <JavaScript file path> -l <log file> -p <parameter #1> -p <parameter #2>Where:-sindicates the JavaScript file to be executed-ldefines the log file
Example with geometry file name and solution settings parametrized:start /wait C:\Program Files\Altair\SimSolid\2020.2\simsolid.exe -s C:\Models\Batch\modal.js -l C:\Models\Batch\log.txt -p pullupbar-v2 -p stress
Batch Mode Examples
Example .js files are located here: <install_directory>\2021\SimSolid2021\Examples\Batch mode.
