User Defined Views
Generator and browser for user defined views.
Use the User defined views dialog to create and restore custom model views. Custom views are model dependent and are always stored in the current project file.
The following functions are available:
Add
Save the current view.
Save modified
Update the selected view.
Delete
Delete the selected view.
Double-click on a view name to rename the view.
You can access your defined custom views from the Standard Views drop-down menu.
