Workflow Guidelines
This section provides best practices and tips on how to effectively use SimSolid capabilities.
The workflow in SimSolid includes preprocessing, solution or solver phase, and postprocessing. The preprocessing step is a short and simple one. It involves loading the model and creating the connections. The solver portion requires turning a few knobs based on the objective of your analysis. These workflow guidelines detail the factors to consider when setting up your analysis to achieve reliable results downstream in SimSolid.
