Learn about the features and functionality available in Compose.
An overview of the utilities and tools in Compose.
Discover new features and enhancements.
Discover Compose, including its language support and system requirements.
The Compose tutorials and associated example model files help introduce you to the basic functionality of the software.
Compose 2022 runs on Windows and Linux 64-bit platforms. Supported platforms include Windows 7/10 and Linux RedHat RHEL 7.4 and SUSE 12SP3.
Open Matrix Language is the primary math and scripting language for Compose.
Compose supports the Tcl scripting language, revision 8.5.9, for editing, execution, and debugging.
Compose supports Python 3.5.4 as a scripting language.
Compose supports R as a scripting language for both edition and execution.
The Compose Integrated Development Environment offers many tools which can be used for authoring and debugging operations.
Learn how to open, create, and close scripts.
Click Run to execute a script.
Run files and profile them at the same time.
In Compose, you can create 2-D and 3-D plots using OML plotting commands.
Use the Debugger to find errors in the script.
The Compose Notebook is a web-based implementation of Compose’s OpenMatrix Language (OML) into a Jupyter Notebook. Notebooks (see www.jupyter.org) are a powerful way to execute and demonstrate scripted languages.
Learn about the method, functions and file input and output options for creating GUI's.
Use the HDF5 Viewer to import data and navigate through the hierarchy of .hdf5 files.
Use the Extension Manager to create custom extensions, load extensions automatically, and add custom documentation for defined features.
OML functions can be registered from the Compose graphical user interface or via a preference file and later opened in certain HyperWorks products.
Additional libraries can be written in the C/C++ or Fortran language and interfaced with OML.
Reference guides are available for functions and commands supported by OML, Tcl, and Python.
