Learn about the features and functionality available in Compose.
Discover new features and enhancements.
Discover Compose, including its language support and system requirements.
The Compose tutorials and associated example model files help introduce you to the basic functionality of the software.
Compose 2022 runs on Windows and Linux 64-bit platforms. Supported platforms include Windows 7/10 and Linux RedHat RHEL 7.4 and SUSE 12SP3.
An overview of the utilities and tools in Compose.
Learn how to open, create, and close scripts.
Click Run to execute a script.
Run files and profile them at the same time.
In Compose, you can create 2-D and 3-D plots using OML plotting commands.
Use the Debugger to find errors in the script.
The Compose Notebook is a web-based implementation of Compose’s OpenMatrix Language (OML) into a Jupyter Notebook. Notebooks (see www.jupyter.org) are a powerful way to execute and demonstrate scripted languages.
Learn about the method, functions and file input and output options for creating GUI's.
Use the CAE Reader to import and work with CAE test data.
Use the CORA and ISO-18571 functions to calculate the correlation metric between test and CAE data.
Use the ReadVector Builder and CAE Reader utilities to read in and handle CAE files and test data.
Use the HDF5 Viewer to import data and navigate through the hierarchy of .hdf5 files.
Use the Extension Manager to create custom extensions, load extensions automatically, and add custom documentation for defined features.
OML functions can be registered from the Compose graphical user interface or via a preference file and later opened in certain HyperWorks products.
Additional libraries can be written in the C/C++ or Fortran language and interfaced with OML.
Reference guides are available for functions and commands supported by OML, Tcl, and Python.
