Modify Object Properties
Use the options in the Property Editor to modify objects in your user interface design.
Object Properties
uiObject Property | Description |
objectName | Specify a name for the object. |
uiWidget Property | Description |
enabled | Select this property to enable the object in the GUI. This
property correlates to the |
geometry | Expand the geometry settings and define the object dimensions
as X and Y or Width and Height. This property correlates to
the |
visible | Select this property to set the visibility of the widget as
on or off. This property correlates to the
toolTip | Enter the tooltip text or specify a file for the tooltip. |
Button Properties
The following properties are specific to push buttons, radio buttons and check boxes.
uiButton Property | Description |
text |
checkable | Select this property to create the uicontrol style of
togglebutton . Otherwise, the code generated is
for pushbutton . |
checked (applies to radio buttons and check boxes.) | Select this property to set the default state of the check box as selected. Selected = true; Not selected = false. |
Input Widget Properties
The following properties are specific to line edit and slider objects.
uiAbstractSlider Property | Description |
minimum | Minimum value of the slider. |
maximum | Maximum value of the slider. |
pageStep | Set the page value for the slider. This value corresponds to the PageUp and PageDown keys. |
value | Initial value of the slider. |
orientation | Select Horizontal or Vertical. |
