Active Port Configuration
Set up the Lua settings file for the active ports in a multiport active ports configuration. Each active port in the configuration requires an excitation and a load specification.
Port Excitation Specification
-- create table to store the source data in activePortsConfiguration = {} -- Source Port1 source = {} source.Label = "Port1" source.Index = 1 source.Value = pf.Complex(1,0) table.insert(activePortsConfiguration,source)
Port Loading Specification
- Direct connection (no additional loading)
- Complex load
- One-port Touchstone network (.s1p)
- Two-port Touchstone network (.s2p)
-- Load options to attach to active port. -- Create load table and load data table activePortsConfiguration.Load ={} activePortsConfiguration.Load.Data ={} -- Type = 1 (direct connection or no loading), load = {} load.Type = 1 table.insert(activePortsConfiguration.Load.Data,load) -- Type = 2 (complex) load ={} load.Type = 2 load.Value = pf.Complex(50,0) table.insert(activePortsConfiguration.Load.Data,load) -- Type = 3 (One port Touchstone network) load = {} load.Type = 3 -- Relative path from settings file location on drive load.Filename = "test.s1p" table.insert(activePortsConfiguration.Load.Data,load) -- Type = 4 (Two port Touchstone network) load = {} load.Type = 4 -- Relative path from settings file location on drive load.Filename = "example.s2p" table.insert(activePortsConfiguration.Load.Data,load)
