Describing material media
Introduction
For all that concerns the describing of the material media:
Specificities connected with the coupling
Generally speaking, for each modeled area the following should be achieved:
  • a magnetic definition
  • a thermal definition
The table below summarizes the main conceivable situations for different parts of the studied device.
The regions belonging to the study domain… are defined by...
(1)
Magnetic and thermal
(ex: heated piece or pieces “important” from the thermal point of view)
a magnetic type:
  • magnetic
  • stranded conductor
  • solid conductor
a thermal type:
  • thermal conducting
(2)
only magnetic
(ex: surrounding pieces without influence from the thermal point of view)
a magnetic type:
  • air or vacuum
  • magnetic
  • solid conductor
a thermal type:
  • inactive
(3)
only thermal (ex: thermal exchange surface with the surrounding air)
a magnetic type:
  • inactive
a thermal type:
  • thermal exchange surface
In the previously presented example…
  • the steel billet is defined from the magnetic and thermal points of view (1)
  • the inductor and the magnetic core are defined only from the magnetic point of view (2)
  • the thermal exchanges surface is defined only from the thermal point of view (3)
