SM coupled with TT: problem description with Flux
Introduction
This section treats the Steady State AC Magnetic coupled with Transient Thermal application and answers the following question: How is a problem described with Flux?
Reading advice
When a problem is described with the Steady State AC Magnetic coupled with Transient Thermal application, you should notice that the main steps are similar to those used:
- on the one hand, to describe a problem with the Steady State AC Magnetic application;
 - on the other hand, to describe a problem with the Transient Thermal application.
That is why the description principle is not completely resumed. Only the elements required by the necessary complementary information, concerning the Steady State AC Magnetic and Transient Thermal applications, are detailed in this section.
