Advice for utilization / advanced mode
Context
The improvements brought about with V12 should permit to treat most of the cases; but it is not possible to ensure 100% of success.
To respond to failure situations (the command for the automatic creation of the cuts has not been successfully completed), a certain number of elements of information are brought in the following sections.
In case of failure
In case of failure of the command for the automatic creation of the cuts, two strategies can be adopted:
- one strategy that imposes the reconstruction of the geometry
 - one strategy imposing the fine adjustment of the command (advanced mode)
In case of failure (1): strategy of reconstruction
In case of failure, a first strategy consists in «re-constructing» and « re-meshing » the geometry. The process is described in the table below. This strategy is quite difficult to put into application as it requires the rebuilding of the links between the geometry and the physic (assigning the regions, electric components, mechanical sets…)
| Step | Action |
| 1 | Delete the mesh |
| 2 | Delete the volumes |
| 3 | Build the volumes |
| 4 | Mesh… |
In case of failure (2): adjustment strategy
In case of failure, a second strategy consists in passing to the advanced mode in order to adjust certain adjustments of automatic creation of the cuts. The command Advanced administration of the cuts… launches the automatic creation of the cuts while taking into account these adjustments. The adjustment elements are described in the table below.
| The choice… | … permits… |
| of the type of cut |
                         to select the type of cut that will be generated by the command :
| of volume regions | to select the volume regions which will be affected by the command |
| of the cuts to be preserved | to preserve the already created cuts (and thus reduce the time of construction of the cuts) |
                         of the number of iterations (concerning the creation of the cuts on the mesh)  |
                     to modify the conditions of operation of the algorithm named « of swelling of the mesh »* |
