Import of geometry called "advanced mode"
Introduction
This section refers to the import of geometry starting from geometric files in « advanced mode ».
The import of CAD geometry into a FE (finite elements) project is an operation which consists of the conversion of the CAD data (in a specified format) into FE type data.
The advanced mode is a method that permits a CAD geometry transfer to the FE software in a more efficient manner while integrating repairs before the conversion of data. These repairs simplify the work of geometry checking/correction.
The formats which permit the import of geometry are as follows:
File format Extension Type of format
IGES (Initial Graphics Exchange Specification) *.IGES, *.IGS standard
STEP (Standard for Exchange of Product) *.STEP, *.STP
ACIS *.SAT proprietary
CATIA V4 *.MODEL
CATIA V5
*.CATPRODUCT
*.CATPART
INVENTOR *.IPT
PROE (Pro Engineer) *.ASM , *.PRT
SOLIDWORKS *. SLDASM , *.SLDPART
NX (Siemens) *.X_T, *. XMT_TXT, *.X_B, *.XMT_BIN
PARASOLID *.PRT
Interest
The user can import a geometry in advanced import mode thereby eliminating the need for the geometric correction phase to follow in FLUX.
Contents
