Initialization by FE solution: particularities
Starting a TM application on the basis of the solution of a MH application
In the case of a TM application starting on the basis of the solution of a MH application, it is necessary to carry out the choice of the phase at the moment of the export of the FE solution.
In the most general case (standard operation *), choose the phase φ = 90° at the moment of the export of the FE solution.
Steady State AC Magnetic application: the sources are maximal while the phase is null (function in cosine)
Transient Magnetic application: the sources are maximal while the phase has the value π/2 (function in sine).
Starting a TM application on the basis of the solution of a TM application
In the case of a TM application starting on the basis of the solution on a TM application, it is necessary to take certain precautions with the cinematic coupling and/or with the circuit coupling.
- Cinematic coupling: at the moment of export of the FE solution:
- Note the value of the speed and of the position of the mechanical set in motion (translation or rotation)
 - Introduce these values in the Flux project 2 (initial values of the mechanical set in motion)
- Circuit coupling: if the current/voltage source is described by means of a time formula, in the Flux project 2, move back in time the current/voltage source.
