Limitations
Introduction
Some limitations remain for this new application :
Geometry and domain
- Symmetries non supported.
 - Periodicities non supported.
Mesh
- The mesh should not be too refined in order to take advantage of this new methodology without overloading the solver which needs to inverse a full matrix.
 - Consequently, it is advised not to import the mesh from an external tool.
Figure 1. On the left, a good mesh for the integral method. On the right, a good mesh for finite element method. - The elements of a mesh must be of the same type (only tetrahedrons or hexahedrons, but do not mix both).
 - No pyramids or prisms (the extrusive mesh is not recommended).
Physics
- Linear isotropic
 - Isotropic analytic saturation (arctg, 2 coef.)
 - Isotropic analytic saturation + knee adjustment (arctg, 3 coef.)
 - Isotropic spline saturation
 - Linear magnet described by the Br module
 - Linear magnet described by cartesian vector Br
- Only magnetic non-conducting volume regions are available.
 - No face regions, line regions and point regions.
- No non-meshed saddle coils.
 - No non-meshed multi saddle coils.
 - No non-meshed coils in open path.
Parameters / Quantities
- No sensors.
 - No Import/Export context.
 - In general, the use of import and export functionalities is not recommended.
Solving
- Solving of the linear system with GMRES only.
 - Solving of the non-linear system with Newton-Raphson algorithm.
Post-processing
- No losses computation (iron losses & joule losses).
 - Available quantities : torque, force, magnetic flux and energy.
 - Only the isovalues and isolines of B and H are available.
 - B and H can be displayed on 2D and 3D grids in the air.
