Compatibilité des composants suivant l'application
Compatibilité composant/application
Le tableau ci-dessous présente les compatibilités entre composants et applications implémentées dans le logiciel FLUX :
| Composant | Magnéto statique | Magnéto harmonique | Magnéto transitoire | Magnéto thermique | |||||
| Flux2D | Flux3D | Flux2D | Flux3D | Flux2D | Flux3D | Flux2D | Flux3D | ||
| Resistance | X | X | X | X | X | X | |||
| Inductance | X | X | X | X | X | X | |||
| Condensateur | X | X | X | X | X | X | |||
source de tension |
Source_tension sinusoidale | X | X | X | X | ||||
| Source_tension à définir | X | X | |||||||
source de courant |
Source_courant sinusoidale | X | X | X | X | ||||
| Source_courant à définir | X | X | |||||||
| Bobine_fil_fin courant | X | X | X | X | X | X | X | X | |
| Bobine_fil_fin circuit | X | X | X | X | X | X | |||
| Massif_2_bornes | X | X | X | X | X | X | |||
| Massif_n_bornes | X | X | X | ||||||
| Interrupteur_inter_ron_roff | X | X | |||||||
| Diode | Diode_uc_i_ron_roff | X | X | ||||||
| Diode_uc_i_exp_vf0_rb | X | X | |||||||
| Diode_uc_i_exponentielle | X | X | |||||||
| Balai_lame | X | X | |||||||
| Cage_ecureuil | X | X | X | X | X | X | |||
| Masse | X | X | X | X | X | X | |||
