Solver Programs
This chapter contains the solver programs.
- Run AcuPrep to parse the input file and prepare it for the solver;
- Run AcuView to calculate radiation view factors, if necessary; and
- Run AcuSolve to solve the problem.
These steps may be performed manually, or automatically using AcuRun. The latter is the preferred mode of operation, since AcuRun hides all the machine-dependent parallel environment setup steps.
