AcuSolve
AcuSolve
2022
  1. Home
  2. AcuReport Reference Manual
    Instruction of the AcuReport tool, a standalone post-processor batch tool used to generate a report from an AcuSolve solution database.
  3. Tufts Functions
  • What's New
  • Get Started
  • Tutorials
  • AcuSolve Training Manual
  • AcuSolve Validation Manual
  • AcuSolve Command Reference Manual
  • AcuSolve Programs Reference Manual
  • AcuSolve User-Defined Functions Manual
  • AcuTrace Command Reference Manual
  • AcuTrace User-Defined Functions Manual
  • AcuReport Reference Manual
  • AcuSolve Surface Processing
Index
AcuSolve
2022
AcuSolve
  • What's New
    View new features for AcuSolve 2022.
  • Get Started
    AcuSolve is a leading general purpose CFD solver that is capable of solving the most demanding industrial and scientific applications.
  • Tutorials
    Discover AcuSolve functionality with interactive tutorials.
    Introduction of background knowledge regarding flow physics and CFD as well as detailed information about the use of AcuSolve and what specific options do.
    Collection of AcuSolve simulation cases for which results are compared against analytical or experimental results to demonstrate the accuracy of AcuSolve results.
    AcuSolve command descriptions and corresponding examples.
    AcuSolve utility programs covering preparatory and post-processing as well as user-defined functions and utility scripts.
    Customization of AcuSolve allowing you to customize certain capabilities of the solver.
    Commands of AcuTrace, a particle tracer that runs as a post-processor to or a co-processor with AcuSolve.
    Instructions to define additional solution quantities of AcuTrace called user equations.
    • Report
      This module creates the .tex file based on the LaTex formatting system by using various methods that work on the report, such as addFigure, addSection and addTable.
    • Adb
      The role of this module is to create an interface to the Acudb module for opening and extracting the last AcuSolve solution database, and transferring its data to the report and plotting them.
    • 2D Plot
      This module defines the curve method for drawing an interpolated curve and the plot method that plots the curve(s) into an image file.
    • 3D Plot
      The 3D plot part role is used to show and change the 3D visualization view of the problem.
    • Example of .Rep File
      The .rep file may look something like the example shown below.
    • Run Time Options for AcuReport
      Each program requires zero or more command-line options to run.
    • Document Generation
    • 2D Plot
    • ReportAcs
      This module defines methods that get data from the database and adds them to the report (.tex) file and are used by the .rep file.
    • AcuSolve Database Access (Adb)
    • Volume Access Functions
    • Surface Access Functions
    • Periodics Access Functions
    • Node Access Functions
    • Scalar and Vector Variables Functions
    • Iso-Surface and Cut-Plane Functions
    • Iso_Line Functions
    • Tufts Functions
      • addTufts()
        Create a Tufts actor.
      • delTufts()
        Remove a Tufts actor.
    • Clip Plane Functions
    • Time Step Functions
    • Display Orientation Functions
    • Add\Remove Actors Functions
    • Set\Get Actors Properties
      Display, transparency, transparency value, color, visibility, line width and point size of the "Surface actors", "Volume Actors", "PBC Actors", "NBC Actors", "Iso-Surface Actors" and "Cut-Plane Actors" can be set through the following functions.
    • Scene Graph Functions
    • Miscellaneous Functions
    • Basic LaTex Tags
      Below are some useful tags in the LaTex formatting system.
    • Acupu Functions
View All Altair Simulation Help
AcuSolve
AcuSolve
2022
  1. Home
  3. Tufts Functions
  • What's New
  • Get Started
  • Tutorials
Index
Tufts Functions
  • addTufts()
  • delTufts()
