udfGetElmContvar()
Return the element contravariant at the quadrature point.
contvar = udfGetElmContvar( udfHd ) ;
User Defined Element
- udfHd
- The opaque handle (pointer) which was passed to the user function.
Return Value
- contvar (Real*)
- Pointer to two dimensional real array of the element contravariant. The first (fastest) dimension of the array is the number of elements, nItems, and the second (slower) dimension is six, for the xx, yy, zz, xy, yz and zx components.
where
is the local parent element coordinate
and
is the global coordinate. The latter is
for the current (deformed) configuration if mesh displacement is active. For example,
Examples
Real* contvar ;
Real xx_contvar, yy_contvar, zz_contvar ;
Real xy_contvar, yz_contvar, zx_contvar ;
Integer elem ;
for ( elem = 0 ; elem < nItems ; elem++ ) {
xx_contvar = contvar[0*nItems+elem] ;
yy_contvar = contvar[1*nItems+elem] ;
zz_contvar = contvar[2*nItems+elem] ;
xy_contvar = contvar[3*nItems+elem] ;
yz_contvar = contvar[4*nItems+elem] ;
zx_contvar = contvar[5*nItems+elem] ;
}Errors
- This routine expects a valid udfHd.
- This routine may only be called within a Body Force, Material Model or Component Model user function.
