udfGetNicIds()
Return the nodal initial condition user node numbers.
nodeIds = udfGetNicIds( udfHd ) ;
AcuSolve User-Defined Name Initial Condition
udfHd
The opaque handle (pointer) which was passed to the user function.
Return Value
nodeIds (Integer*)
Pointer to one dimensional integer array of user node numbers. This array has a dimension of number of nodes, nItems.
This routine returns the array of user node numbers. For example,
Integer* nodeIds ;
Integer usrNode, node ;
for ( node = 0 ; node < nItems ; node++ ) {
 usrNode = nodeIds[node] ;
  • This routine expects a valid udfHd.
  • This routine may only be called within a Nodal Initial Condition user function.
