ACU-T: 4102 Fluidized Bed using the Granular Multiphase Model
Prerequisites
This tutorial provides the instructions for setting up and running a gas-solid fluidized bed simulation using the granular multiphase model. Prior to starting this tutorial, you should have already run through the introductory HyperWorks tutorial, ACU-T: 1000 HyperWorks UI Introduction, and have a basic understanding of HyperWorks CFD and AcuSolve. To run this simulation, you will need access to a licensed version of HyperWorks CFD and AcuSolve.
Prior to running through this tutorial, click here to download the tutorial models. Extract ACU-T4102_FluidizedBed.hm from HyperWorksCFD_tutorial_inputs.zip.
Problem Description
| Phase | Density (kg/m3) | Viscosity (Pa s) |
| Gas | 21.56 | 1.781e-05 |
| Particle | 910 | - |
Start HyperWorks CFD and Open the HyperMesh Database
Validate the Geometry
Figure 3.
Set Up Flow
Assign Material Properties
Generate the Mesh
Define Nodal Outputs
Define the Nodal Initial Conditions
Run AcuSolve
Post-Process the Results with HW-CFD Post
Summary
In this tutorial, you learned how to set up and solve a fluidized bed simulation using the Granular multiphase model available in AcuSolve using HyperWorks CFD. You started by importing the HyperWorks CFD input database and then defined the flow setup. Once the solution was computed, you created a contour plot of particle volume fraction using HyperWorks CFD Post.
