Before exporting the model, the setup can verified and checked for errors using the
Data Check tool. This is accessed from the Solution Browser. Right-click the
Solution Name and select Data Check. SimLab will submit the input files to nFX[p] and show the
output log in the Output Window. This will report the status of the model and
highlight any issues found in the setup.
Attention: The Data Check tool requries the Output
Window to be enabled via View > Output Window.
To
Export the model, rightclick the Solution Name in the Solution Browser and select
Export Solver Input File. You can choose to export just the
Configuration files (*.cfg) or both the Particle
(*.prtl) and Configuration files.
Note: STL walls, Stencil Files for Inlet regions and Probes, and
Time History files are considered part of the Configuration file and are exported
together.
Important: Only the SPH bodies
selected in the Solution will be exported. This can be verified by double-clicking
the Solution Name and viewing the bodies in the Solution menu.
