Altair Simulation
Altair Simulation
2022
  1. Home
  2. Altair Simulation Tools
    Administrative tools to customize your Altair Simulation installation.
  3. HyperWorks GUI Toolkit
    The Altair GUI Toolkit is a resource tool for coding Tcl/Tk dialogs. It contains documentation of the HyperWorks commands, demo pages that illustrate our Altair GUI standards, and sample code for creating those examples.
  4. Utils
  • What's New
  • Altair Simulation Introduction
  • Tutorials
  • Altair Simulation Tools
Index
Altair Simulation
2022
Altair Simulation
  • What's New
    View new features for Altair Simulation 2022.
    Quick introduction to Altair Simulation products.
  • Tutorials
    Discover the functionality of Altair Simulation products with interactive tutorials.
    • Altair License Utility
      The Altair License Utility is a tool allowing you to determine a host ID, check license usage, borrow licenses, and set up hosted Altair Units.
    • Altair Compute Console
      Altair Compute Console (ACC) is a utility that allows you to start different Altair Simulation Solvers.
    • Remote Job Submission
      Remote Job Submission in Altair Compute Console (ACC) is implemented as an alternative to a local run.
    • Remote Server User Guide
    • AbaqusODB Upgrade
      AbaqusODB UpGrade is a HyperView tool, which upgrades ODB files created in Abaqus 2016 (or earlier) to Abaqus 2021.
    • HvTrans
      HvTrans is a result translator for HyperView that translates solver result files to .h3d files.
    • HyperWorks GUI Toolkit
      • Base Widgets
      • Compound Widgets
      • Dialogs
      • Miscellaneous
      • Utils
        • hwtk::image
        • hwtk::settings
      • Validation
        The -validate, -validatecommand, and -invalidcommand options are used to enable entry widget validation.
      • Specify File Patterns
      • Write a New Custom Widget
        Steps and examples for writing a custom widget using the toolkit.
    • HyperWorks Cleanup Utility
      The HyperWorks Cleanup Utility is a script for Windows that removes any custom settings that you may have due to HyperWorks.
    • Model Identification Tool
      The Model Identification Tool, known as HyperWorks, is a profile in HyperGraph for fitting test data from frequency- and amplitude-dependent bushings to analytical models. The HyperWorks operates in conjunction with HyperGraph, MotionView and MotionSolve to provide you with a comprehensive solution for modeling and analysis.
    • Register HVPcontrol
      Register HVPcontrol registers the HVP ActiveX control for HyperView Player.
    • HgTrans
      HgTrans translates solver results files from their native file format to Altair Binary Format (ABF). This can be done using the HgTrans GUI or via the HgTrans batch mode.
    • HyperWorks Automation Toolkit
      The HyperWorks Automation Toolkit (HWAT) is a collection of functions and widgets that allows an application to quickly assemble HyperWorks automations with minimal effort and maximum portability.
    • H3D Validation Tools
      The H3D Validation Tools available in HyperWorks are H3D Info and H3D Validate.
    • Uninstall
      Use the Altair Simulation Products Uninstaller to remove all files from the installation directory.
View All Altair Simulation Help
Altair Simulation
Altair Simulation
2022
  1. Home
  2. ...
  3. Utils
  • What's New
  • Tutorials
Index
ON THIS PAGE
    Utils
    • hwtk::image
    • hwtk::settings
    ON THIS PAGE
