Run HyperWorks in Batch Mode
The HyperWorks runs in batch mode using the Python script, mit_batch.py. With this script, the HyperWorks generates one output .gbs file and one output .spd file for one bushing. The .gbs file can be used for downstream simulation with MBD solvers or applications such as MATLAB, while the output .spd file provides information about the behavior of a model. For example, you can interactively load the output .spd file in the HyperWorks, and then review the performance of your model against the same tests that were used to generate the input .spd file. For more information about .gbs and .spd files, see Altair Bushing Model.
Set the Location of HyperWorks Python
If Python is not installed on your system, then include the location of HyperWorks Python in your path as follows:
Create Shortcuts to the Python Script
Using shortcuts to invoke mit_batch.py helps minimize typing. You can create shortcuts as follows:
Modes of Operation
| Mode | Description |
| option -i | Invokes mit_batch.py with a list of input .spd files. |
| option -d | Invokes mit_batch.py with a directory containing a set of .spd files for a bushing. |
Synopsis of Batch Mode Options
| mit_batch.py | i <input_files_list> | -o <output_directory> | <options> |
| mit_batch.py | -d <input_directory> | -o <output_directory> | <options> |
Arguments
- Argument
- Description
- -i <input_files_list>
- Specifies a list of comma-separated .spd file names that are to be fitted. You can provide a maximum of six files as input. The directions to be fitted are obtained from the .spd files and must be unique.
- -d <input_directory>
- Specifies a path that contains the files that are to be fitted. The tool attempts to run all .spd files in this directory. The directory must contain a maximum of six .spd files, each of which contains a unique direction. The bushing directions to be fitted are obtained from the .spd files. The arguments -i and -d are mutually exclusive.
- -o <output_directory>
- Specifies a path where all outputs from the run are placed.
<output_directory> is created if necessary.
/staff/brown/rear-gear-box is an example of a
valid output directory path. <output_directory>
contains the following five files:
- Output .gbs file
- <name>.gbs
- Batch .log file
- <name>.batch.log
- .xml file
- <name>.xml
- Fit .log files
- These files summarize the fit effort. One .log file is generated for each fitted .spd file. The prefix of each .log file matches the .spd file that is fitted. Thus corresponding to the .spd file rear-gear-box-z.spd, a .log file rear-gear-box-z.log is created. When the –e <experiment-directory> option is used, the fit .log files are created in <experiment-directory>.
- Subdirectory, 1_Cycle
- This directory contains files useful for the HyperWorks. You should not change the contents of this directory. When the –e <experiment-directory> option is used, the subdirectory, 1_Cycle is created in <experiment-directory>.
Options
- Option
- Description
- -a
- Specifies that the HyperWorks is to perform an analyze operation. The analyze operation performs a test on a virtual bushing and compares the results to the physical test results. The virtual bushing is specified as an input .gbs file. The physical test is specified in an input .spd file. When this option is not specified, the system tries to perform a fit operation with the specified inputs.
- -e
- Specifies the directory name where the intermediate files that the HyperWorks generates from a fit or analyze operation are stored. You can use these files to reload existing runs in a new HyperWorks session. You should not change the contents of this directory. When this option is not used, all output files are created in the output folder.
- -f <xml-file>
- Specifies the .xml file containing the options that are to be used for fitting. These options take precedence over the options in the default .xml file that is used by the HyperWorks.
- -h
- Provides information about how to use mit_batch.py. Invoking mit_batch.py without parameters also provides Help, which is this content shown in plain text.
- -n
- Specifies the name of the output .gbs file, output .pdf file, batch .log file and .xml file. If not specified, <name> is the lowest level directory name in <output_directory>.
- -t <directory>
- This option is meant for use only when the –i argument is used. This option specifies a test directory where the .spd files reside.
- -x
- Does not execute the HyperWorks, but generates an output directory that includes the .xml file of default options.
Return Status
- Status
- Description
- 0
- The fitting tasks were completed successfully.
- 64
- The analyze tasks were completed successfully.
- 1
- The fitting task for FX direction failed.
- 2
- The fitting task for FY direction failed.
- 4
- The fitting task for FZ direction failed.
- 8
- The fitting task for TX direction failed.
- 16
- The fitting task for TY direction failed.
- 32
- The fitting task for TZ direction failed.
- Fitting task failed for FX and FZ: the return code is 0+1+4 = 5.
- Analyze task failed for FX and FZ: the return code is 64+1+4 = 69.
Batch Mode Examples
mit_batch.py –i ./F0_Fx.spd –o ./F0_Fx- The file F0_Fx.spd in the current working directory is used as the input .spd file.
- The HyperWorks creates an output directory file,
./F0_Fx, in the current working directory. The
./F0_Fx file contains the fit results:
Table 1. Result Description F0_Fx.gbs Output .gbs file for simulations. F0_Fx.pdf Output .pdf file. F0_Fx.batch.log .log file for the batch run. F0_Fx.xm Parameters used by the HyperWorks for this run. F0_Fx.log .log file for the fit operation on F0_Fx.spd. 1_Cycle Sub-directory containing intermediate files generated by the HyperWorks.
mit_batch.py –d /staff/pbrown/rear-gear-box –o /staff/pbrown/rear-gear-box-09-19-2013- All .spd files in /staff/pbrown/rear-gear-box are used as input to the HyperWorks. Assume that there are three .spd files in /staff/pbrown/rear-gear-box, rgb-90210-x.spd, rgb-90210-y.spd, rgb-90210-tz.spd, for directions x, y and tz respectively.
- The HyperWorks creates an output directory,
/staff/pbrown/rear-gear-box-09-19-2013, which
contains:
Table 2. Result Description rear-gear-box-09-19-2013.gbs Output .gbs file to use for simulations. rear-gear-box-09-19-2013.pdf Output .pdf file. rear-gear-box-09-19-2013.batch.log .log file for the batch run. rear-gear-box-09-19-2013.xml Parameters used by the HyperWorks for this run. rgb-90210-x.log .log file for the fit operation on rgb-90210-x.spd. rgb-90210-y.log .log file for the fit operation on rgb-90210-y.spd. rgb-90210-tz.log .log file for the fit operation on rgb-90210-tz.spd. 1_Cycle Sub-directory containing intermediate files generated by the HyperWorks.
mit_batch.py –d /staff/pbrown/rear-gear-box –o /staff/pbrown/rear-gear-box-09-19-2013 -x- All .spd files in /staff/pbrown/rear-gear-box are used as input to the HyperWorks. Assume that there are three .spd files in /staff/pbrown/rear-gear-box, rgb-90210-x.spd, rgb-90210-y.spd, rgb-90210-tz.spd, for directions x, y and tz respectively.
contains:
Table 3. Result Description rear-gear-box-09-19-2013.batch.log .log file for the batch run. rear-gear-box-09-19-2013.xml Parameters used by the HyperWorks for this run.
mit_batch.py –i F0_Fx.spd, F0_Tx.spd –o ./F0 –t /staff/pbrown/rear-axle-bearing- The HyperWorks uses the files F0_Fx.spd and F0_Tx.spd in /staff/pbrown/rear-axle-bearing as the input .spd files.
F0, in the current working directory. The
F0 directory contains:
Table 4. Result Description F0.gbs Output .gbs file to use for simulations. F0.pdf Output .pdf file. F0.batch.log .log file for the batch run. F0.xml Parameters used by the HyperWorks for this run. F0_Fx.log .log file for the fit operation on F0_Fx.spd. F0_Tx.log .log file for the fit operation on F0_Fy.spd. 1_Cycle Sub-directory containing intermediate files generated by the HyperWorks.
mit_batch.py –i F0_Fx.spd, F0_Tx.spd –o ./F0 –t /staff/pbrown/rear-axle-bearing -n exported- The HyperWorks uses the files F0_Fx.spd and F0_Tx.spd in /staff/pbrown/rear-axle-bearing as the input .spd files.
Table 5. Result Description exported.gbs Output .gbs file to use for simulations. exported.pdf Output .pdf file. exported.batch.log .log file for the batch run. exported.xml Parameters used by the HyperWorks for this run. F0_Fx.log .log file for the fit operation on F0_Fx.spd. F0_Tx.log .log file for the fit operation on F0_Fy.spd. 1_Cycle Sub-directory containing intermediate files generated by the HyperWorks.
mit_batch.py –i F0_Fx.spd, F0_Tx.spd –o ./F0 –t /staff/pbrown/rear-axle-bearing -n exported -e/staff/pbrown/Test- The HyperWorks uses the files F0_Fx.spd and F0_Tx.spd in /staff/pbrown/rear-axle-bearing as the input .spd files.
- The HyperWorks creates an experiment directory,
Test, in the current working directory. The
Test directory contains:
Table 6. Result Description exported.batch.log .log file for the batch run. exported.xml Parameters used by the HyperWorks for this run. F0_Fx.log .log file for the fit operation on F0_Fx.spd. F0_Tx.log .log file for the fit operation on F0_Fy.spd. 1_Cycle Sub-directory containing intermediate files generated by the HyperWorks. - The HyperWorks creates an output directory,
Table 7. Result Description exported.gbs Output .gbs file to use for simulations. exported.pdf Output .pdf file
