NX Reader
NX import is available through two different readers: UGOpen native reader and a third-party non-native reader.
View new features for HyperWorks CFD 2022.
Discover HyperWorks CFD functionality with interactive tutorials and community resources.
File formats supported by HyperWorks CFD.
Create a new file.
Open a file.
Import an existing file to the current session.
Learn about the CAD readers supported by HyperWorks CFD and the options available for importing CAD geometry data.
CAD readers supported by HyperWorks CFD.
The NX reader utilizes the UGOpen library to read files from NX.
The NX Third Party reader does not need a valid NX installation or license to access these libraries.
CAD readers provide options for processing data during import.
Each reader reads the CAD file and sends the geometry information to HyperWorks CFD. When a CAD file is read, a .msg file is created (or appended to) in the current working directory.
Learn about possible difficulties you may encounter during CAD import.
The metadata names generated by the CAD readers are composed of a general prefix followed by a metadata specific name.
The prefix is specified using the @MetadataPrefix
option in each _reader.ini file.
Import FE models for supported solver interfaces.
Save all of the data in your current session.
Export FE data in your current session.
Record a video or take a snapshot of the screen.
Set up the simulation model, materials, domains, and boundaries.
Define radiation conditions and create emissivity models.
Define direct, derived, and constrained mesh motion.
Generate surface/volume mesh by defining mesh controls, or interactively create and edit 2D surface mesh.
Define output conditions, run the simulation, and view the results.
Use the Template Manager to define rule-based logic for groups, geometric operations, and setup and automate simulation processes.
Post-process the simulation results by creating visualizations and measurements.
Click here to access AcuSolve online help.
ON THIS PAGE
ON THIS PAGE
