Post-Processing Analysis
Result databases can be used during post-processing to create contour, assigned, deformed, and vector plots.
Review results files and databases generated by external codes using post-processing tools. Results files can be translated into HyperMesh results databases which are then read into HyperMesh for post-processing. This translation is done using result translators; for more information, refer to the individual translators in the Interface help system.
