Add a Datum Line to a Plot
- From the Datum Lines panel, select Horizontal or Vertical.
                Click Add.
                The datum line name is displayed in the datum list.
- Enter a new name for the datum line in the text box above the datum list.
                Press Enter.
                The new name is displayed in the datum list.
- By default, the Datum check box is active and the datum line is displayed in the plot.
For polar plots:
- From the Datum Lines panel, select Phase or Magnitude.
- Follow steps 2-5 above.
