RBDO
Set up a reliability-based optimization (RBDO) and execution by defining objective of decoupling rigid body modes, creating constraints for rigid body mode frequencies and specifying design space for variables in terms of mount stiffness, locations, and inclinations.
Specify a design space for design variables. It can be set from nominal values or optimized values from a deterministic optimization run.
Figure 1. Mount Optimization Utility - Study Tab – RBDO sub-tab – Des Vars
Define an objective for rigid body mode decoupling criteria.
Figure 2. Mount Optimization Utility - Study Tab – RBDO sub-tab – Objective
Create constraints for rigid body mode frequencies and specify system reliability.
Figure 3. Mount Optimization Utility - Study Tab – RBDO sub-tab – Constraint
Display and compare rigid body mode frequencies and kinetic energy, baseline vs. optimized. Show the review comparison of design variables, optimized vs. baseline. You can save the configuration file with optimized design variables for further studies.
Figure 4. Mount Optimization Utility - Study Tab – RBDO sub-tab – Display
