RAD2NOISE
Use the RAD2NOISE dialog to create an input file based on your inputs.
This input file can be used to run the RAD2NOISE solver in batch mode. The RAD2NOISE function supports input file creation for the following solutions possible with the RAD2NOISE solver:
  • Fourier Transformation
  • Model extraction from time domain or frequency domain input.
  • Acoustic calculation from time domain or frequency domain input.
  • Spectrum to Octave bands.
  • Pressure to Spectra bands.
See the RAD2NOISE topic in the HyperView Interfacing on-line help for more information.
