HyperGraph
HyperGraph
2022
  1. Home
  2. Get Started
  3. User Interface
    The user interface provides you with a consistent look and feel when you are working in any of the HyperWorks Desktop applications.
  4. HyperGraph 2D Menus
    The HyperGraph 2D menus provide quick access to panels and tools.
  5. Plot Types
    Select one of four plot types: XY Plot, Bar Chart, Complex Plot, or Polar Plot. XY Plot is the default plot type.
  • What's New
  • Get Started
  • Tutorials
  • HyperGraph 2D
  • HyperGraph 3D
  • HyperGraph Solver Interfacing
  • Templex and Math Reference Guide
  • HyperWorks HyperGraph Help
Index
HyperGraph
2022
HyperGraph
  • What's New
    View new features for HyperGraph 2D 2022.
  • Get Started
    • Supported Files in HyperGraph
      HyperGraph can read the following types of plot data files:
    • User Interface
      • HyperGraph 2D Menus
        • Plot Types
        • Curves
          The Curves menu allows you quick access to commonly used panels and tools. The Curves menu options change, depending on the selected plot type (XY Plot, Bar Chart, Polar Plot, and Complex Plot).
        • Annotations
          The Annotations menu provides quick access to the Axes, Legends, Headers and Footers, and Notes panels. The panels available on the Annotations menu are the same for all plot type options.
        • Tools
          From the Tools menu, you can access panels to plot statistics and retrieve individual point data.
        • Preferences
          From the Preferences menu, you can define file export settings and access the Options panel.
        • HyperGraph 2D Context Sensitive Menus
          From the HyperGraph 2D modeling window, right-click to display the HyperGraph 2D context-sensitive menu.
      • HyperGraph 2D Toolbars
        The HyperGraph 2D toolbars provide quick access to commonly used panels and tools.
      • Tab Area
        The Tab Area is the portion of the graphical user interface that contains the browsers, utilities, and other functionality not shown in the panel area.
      • Plot Browser
        The HyperGraph Plot Browser is located in the tab area sidebar and allows you to view the HyperGraph plot structure.
      • NVH
        From the HyperGraph 2D NVH menu, the following options are available.
      • Vehicle Safety Tools
        The Vehicle Safety Tools (VST) is a collection of over 200 macros, Templex functions, and external functions for use by a vehicle safety engineer.
      • Model Identification Tool
        The Model Identification Tool, known as MIT, is a profile in HyperGraph 2D for fitting test data from frequency- and amplitude-dependent bushings to analytical models.
  • Tutorials
    Discover HyperGraph 2D and HyperGraph 3D functionality with interactive tutorials.
  • HyperGraph 2D
    Powerful data analysis and plotting tool for all types of CAE data.
  • HyperGraph 3D
    HyperGraph 3D offers a 3-D plotting environment that is fully integrated with Altair Simulation, for managing, reviewing, and analyzing 3-D plots such as waterfall, surface, and 3-D line data.
    Supported solvers in HyperGraph.
    HyperGraph help for HyperWorks.
View All Altair Simulation Help
HyperGraph
HyperGraph
2022
  1. Home
  2. Get Started
  3. User Interface
  5. Plot Types
  • What's New
  • Get Started
  • Tutorials
  • HyperGraph 2D
  • HyperGraph 3D
Index
Plot Types
Figure 1. Plot type menu
The following panels are available for each plot type:
Plot Type Panels Available
XY Plot Build Plots
Plot Macros
Define Curves
Datum Lines
Modify Curves
Curve Attributes
Coordinate Info
Statistics
Scales, Offsets, and Axis Assignments
Axes
Legends
Headers and Footers
Notes
Options
Bar Chart Define Curves
Datum Lines
Curve Attributes
Axes
Legends
Headers and Footers
Notes
Options
Complex Plot Build Plots
Plot Macros
Define Curves
Datum Lines
Coordinate Info
Curve Attributes
Axes
Legends
Headers and Footers
Notes
Options
Polar Plot Build Plots
Define Curves
Define Tip-to-Tail
Datum Lines
Curve Attributes
Coordinate Info
Scales, Offsets, and Axis Assignment Panel
Axes
Legends
Headers and Footers
Options
