Offset Curves Along the Mag Axis
  1. From the Complex plot toolbar, select the Scales, Offsets, and Axis Assignments panel.
  2. Select the curves from the list or pick them from the window.
  3. Turn on the YM offset check box and enter the distance to shift the curves in the text box.
  4. Click Apply to accept the new scaling values.
    The data is shifted up for positive values and down for negative values.
