Select a File with Complex Data Without Frequency Data
  1. From the Polar Plot toolbar, select the Build Plots panel.
  2. Select a column or other HyperGraph plot file that contains complex data but no frequency data.
    HyperGraph enables the Phase Request and Phase Component fields.
  3. HyperGraph populates the filename Subcase, Type, and Request fields.
  4. Select the phase Type, Request and Component.
  5. Select the magnitude Type, Request and Component.
  6. Click Apply.
    The curve names, header/footer axes labels, and page titles are created.
    The curves are plotted as Phase/Magnitude plots.
    Note: HyperGraph requires that the Phase is in degrees.
