Offset Curves Along the Phase Axis
  1. From the polar plot toolbar, select the Scales, Offsets, and Axis Assignments panel.
  2. Select the curves from the list or pick them from the window.
  3. Activate the Phase offset check box.
  4. Enter the distance to shift the curves in the Phase offset text box.
  5. Click Apply to accept the new scaling values.
    The data is shifted to the right for positive values and to the left for negative values.
