Weld Lines
Use the Mark Welds tool to detect, create, edit, and delete weld lines.
The weld lines created via Mark Weld in HyperMesh acts as preprocessing steps for the weld fatigue setup in HyperLife Weld Certification. The HyperMesh file saved with the weld line information can be imported into HyperLife Weld Certification as a model file.
The following topics provide an introduction to the weld line and its features.
