Deactivate Input Variables
By default, all input variables imported or manually added to your study are made active. Make an input variable inactive so that it is no longer an independent variable.
Reducing the number of independent variables can reduce the number of runs required in an Optimization or DOE approach.
In the Define Models step, Active column, clear the input variable's corresponding checkbox.
